Someone can guide me with a jetta ..........
17 years 1 month before #3120 by manual-mecanica
Someone can guide me with a jetta .......... published by Manual-Mecanica
Hello, busoando I found her page and is great, congratulating them for her, I allow myself But I take it with someone else and say that it is fine in perfect condition ..... Someone can guide me what I can do .... to whom I pay attention, the two have scanned them ....... It is an annoying to walk like this .... By the way to started cats more gasoline than normal ... in advance thanks ......
17 years 1 month before #3134 by manual-mecanica
If the car is injected, check the Lambda probe possibly defective and check the temperature sensor is possibly outstanding, it can also be the pump or pump relay with pressure variation
17 years 1 month before #3219 by manual-mecanica
Hey Papace What I can tell you is what I did to my jetta 95 that rattle and spent a lot of gasoline, the air filter took the hose that goes to the air filter and gave them a good washing one another one took away the lambda probe and all the sensors that I found were cleaned and with that it was composed swimming I even degraded the engine of the engine. or four weeks since it was weightless as if gasoline came to the echo oil, smoke, and when doing that you take away the oil is perfect with a viscosity that had about seven months that it was not seen and it is what I personally happened to me and the jettas are somewhat complicated I hope to help you and answer me if it serves you or not luck.
