Does not turn on Chevrolet Blazer
17 years 1 month before #3122 by manual-mecanica
Does not light Chevrolet Blazer published by Manual-Mecanica
Hello everyone, I have problems with the ignition of a Chevrolet Blazer, the problem started when the temperature of the car went up and if it went out I did not turn on had to wait for it to cool to be able to start it again, now it does not turn on.
I appreciate your help in advance and if someone has the workshop manual, I thank you for
17 years 1 month before #3141 by manual-mecanica
Manual-Mecanica Answer on the Re: Does not light Chevrolet Blazer
If it is ancient model of Cecala coil, maybe it is burn when you reheat and that's why it doesn't turn on you
17 years 1 month before #3148 by manual-mecanica
Hello, how are you blazer is injection with TBI system because if so, it can depend on oil pressure since the pump works with oil pressure, consume water? That it can also be the Fan Cluch, what goes out can be several things can be the coil, it can be a fuel pressure, another question when it is requisitive, it boots you water through the boat or water storage of the radiator or by the lid, you have controlled if the radiator has water taking the lid of the same, do these tests and make me know. Greetings Alfredo
17 years 1 month before #3156 by manual-mecanica
Thank you, the blazer is a model 98 if I had problems that you consume the water, disconnect a spark plug to try if it throws spark and if there is, if you boot water through the boat. I have a little doubt about the gasoline pump, I change it 4 months ago I have not put the original and I have doubts about it.
I appreciate your attention.
17 years 1 month before #3163 by manual-mecanica
Ok It is enough that the pump is for monoaining, the pump does not matter whether or not it is original that the necessary pressure is sent to you, because of the water can Four black cables if I am not mistaken, also check the radiator lid, take good but the first if you can change the thermostat that is the most economical for these cases and it is very common for this type of breakdown, try and let me know I greet you, I greet you Alfredo.-
