Hyndai Alantra 2002 Failure
17 years 1 month before #3244 by manual-mecanica
Hyndai Alantra 2002 Failure published by Manual-Mecanica
I have a 2002 Elantra with a check Engine, apply the scanner and shoot a dismisssed foal fault cylinder 3 and then in 4, first change spark plugs, then plug cabble, then the ignition coil, subsequently clean injectors, and change the O2 sensor, and the problem continues, the car is normal but the engine has a small failure that does not stabilize it. revolution, what can it be?
17 years 1 month before #3259 by manual-mecanica
Manual-Mecanica Response on the Re: Hyndai Elantra 2002 Failure
You check the compression in the cylinders, you changed two or four spark plugs and just like the cables it can also be some disconnected air mangued check and let me know.-
