Failures Help
17 years 1 month before #3276 by manual-mecanica
Failures Published by Manual-Mecanica
Good help please
I have a 93 golf, the needle that marks the level of de -peak gasoline no longer marked, already disconnect the battery for a few minutes, check the fuses and they are fine, someone could tell me if there is something that can do or definitely take it to the good electric that is on the one hand and it is also very slow in the roller and consumes me a lot Spark plug wires does not bring catalyst and recently changed the exhaust tube I don't know if that damages the sensor thanks: blush:
17 years 4 weeks before #3291 by manual-mecanica
Manual-Mecanica Response on the topic Re: Fallas Help
Disconnect the cable that is connected to the float and make earth or dough and see if the needle goes up if it goes up is the float that is damaged
17 years 3 weeks before #3322 by manual-mecanica
My good I have a Jetta 95 and I spend the same thing with several electric ones and they reviewed it in the way that the good short circuit tells you and the result is that the board is evil tell me the electric ones that the VW have that fault but check it as it tells you Short Cytus Good luck bye.
17 years 3 weeks before #3326 by manual-mecanica
I have a Nissan Sentra B14 1998 and every morning when lighting it, the parking brake bulb is caught
17 years 3 weeks before #3331 by manual-mecanica
See if you lack brake league if the level is low check if the brake pads are spent. Greetings Alf.-
