The starter engine turns to the contrary
17 years 4 weeks before #3295 by manual-mecanica
The starter engine on the contrary published by Manual-Mecanica
Well, that guys turn out that I have a Yamaha Tzr of 80cc, and I have the problem that the starter has begun to rotate on the contrary and of course the engine is not started, at the same way my starter engine looking at the pinion acia my turn right, when I think I should approach it to the left, do you know what I can do? or if it can be the failure of the relief that the current or something sends you? I once passed?
Thanks
greetings
17 years 4 weeks before #3301 by manual-mecanica
Manual-Mecanica response on the Re: the starter engine turns on the contrary
Hello if you disassembled the donkey and you have the compos of magnet
17 years 4 weeks before #3306 by manual-mecanica
Hello, my name is Juanj, I tell you, the electric (starting) motors of 6 or 12 continuous volt will depend on the connection (+o-to determine the direction of rotation, the relay has absolutely nothing to do in the direction of rotation, correct connection and it would be Todp
atte JJ, understood in the subject
17 years 4 weeks before #3307 by manual-mecanica
Hello, how are you for these cases, check the position of the boot brush holder if you can swim it, give a Jiro room and change a lot of luck a lot of luck
17 years 4 weeks before #3313 by manual-mecanica
Let's see, because they do not ask colleague project first of all that made the start? And then we can give you some fair answer because I think we are confusing it more, it is my humble opinion Alf.-
