Daewoo cloud airbag
13 years 2 months before #33244 by manual-mecanica
Airbag Daewoo Nubira published by Manual-Mecanica
Hello friends, I have a problem with the airbag, the light is lit in the painting, I put the machine and give me 2 codes: 10-TRANSDUCTOR LOW PRESSURE PASSENGER SEAT TO MASS.).
It is a Daewoo Nubira of the year 2003/CC/1600/F16D3
a thank you.
13 years 2 months before #33374 by manual-mecanica
Manual-Mecanica Answer on the Re: Airbag Daewoo Nubira
You must check that the connections are given, usually when the light of the Air Bag turns on without colliding is due to a bad connection that can be given by maintenance as interior aspirations and cables are released, check the connections, or you can perform maintenance to the module connector that controls the Air Bag, which in that car is in the middle of the driver's seat and the passenger. The Air Bag of your car, I have it and I can send it.
All the best.
12 years 8 months before #37809 by manual-mecanica
Hello, how ta andres, look yi I have the same problem,
and looked at the connections under the seats and are fine, if you could send me the manual telo would appreciate,
My choreo is
Greetings and thanks.
8 years 1 month before #52199 by manual-mecanica
Manual-Mecanica Airbag Daewoo Nubira Airbag
Hello, I would like that manual my email is thank you
