Automatic Ford Windstar Transmission 1995
17 years 1 week before #3495 by manual-mecanica
Automatic Ford Windstar Transmission 1995 Published by Manual-Mecanica
[File] We repair an Axod-E trans, but in the road test the converter clutch does not apply, there are no fault codes.:(
17 years 1 week before #3499 by manual-mecanica
Manual-Mecanica Response on the Re: Automatic Transmission of Ford Windstar 1995
That there is a Czech old man
that the oil that you put is adequate, checks if in the barilla of the level the meron v recommends, if you do when you put a dexron 3 it tends to fail.
