Use the board fuse or in the original radius connector you should have a cable or you can usal the lighter light cable or you can also put a relationship that when you turn off the car the lights go out the lights cutting the current that goes in charge of the lights sees what you want to do and if you need help, let me know Greetings Alfredo.-
