Front seat disassembly of a Scenic
17 years 4 days before #3564 by manual-mecanica
Front seat disassembly of a Scenic published by Manual-Mecanica
Hi: You know if you can disassemble the sorry Dcho striker. without \ "block the airbag calculator with the diagnostic tool \". I do not have that useful and I need the space to transport a large object.
Thanks in advance.
17 years 4 days before #3568 by manual-mecanica
Manual-Mecanica Answer on the Re: front seat disassembly of a Scenic
See if you have the key to disable the passenger side airbag, and see if you have the connector at the bottom of the seat if you have a yellow envelope is the airbag cable sometimes if you disconnect it and you connect it again, nothing happens as you can also look on and you would only have to make a mistake of errors if you do not have the cable below the seat should not happen to you.
17 years 4 days before #3571 by manual-mecanica
Thank you very much: I do have a key to cancel the airbag and cables that connect the seat to the car of the car.
Can I know the user and without specialized tool the error codes?
17 years 2 days before #3588 by manual-mecanica
I have the workshop manual where it is explained how to remove the seat, but I do not have the diagnosis useful.
The doubts that arise are: once removed you can drive without the seat (active alarms, etc.) and when the airbag will put the seat and there will be no alarm.
Thank you.
17 years 1 day before #3594 by manual-mecanica
Normally the Air Bag code is not eliminated without the device but proves to see if after disconnecting it and using the car and when connecting it makes the reset the switchboard, disconnects the key before disconnecting the seat.
