CORSA Party Problem
16 years 11 months before #3669 by manual-mecanica
CORSA CHARGE PROBLEM PUBLISHED BY MANUAL-MECANICA
Hi, my brother tells me about a problem that has Corsa year I think it's a lot 2005 1.6, it is not the only Corsa that after having walked about 10 minutes if the engine does not want to teach again.
Someone can help me to solve it,
I will appreciate them enough
: UNSURE:
16 years 11 months before #3674 by manual-mecanica
Manual-Mecanica Response on the Re: Corsa Private Problem
It is gasoline or diesel, if it is gasoline, check the crankshaft srsor that may not be the signal or fuel pressure if it is diesel can be either the heater or the pump, in both cases check the fuel filter.-
16 years 11 months before #3676 by manual-mecanica
Hello, thanks for the answer, it is gasoline, to refer to the crankshaft sensor, I am new in this mechanics. thank you
16 years 11 months before #3696 by manual-mecanica
It is a sensor that is placed on the rear of the engine and is the one that gives the signal to the switchboard so that the car has current for the ignition, it may not have enough fuel pressure to make it start, it can be the air flow sensor \ "maf \" that does not send a good sign or have the chapaleta of the dirty acceleration body and have to clean it and make the parameters or operating rule with a computer Diagnosis and another thing that is not to rule out the temperature sensor, in addition the spark plugs since when you do not change them, hax ​​these tests and warn me, greetings Alfredo.-
16 years 11 months before #3713 by manual-mecanica
In Realida, the majority of the Corsa suffers from a degaste between the Sigual and the Distribution Piñon. This game produces a delay and progress in the time of vehicle so the car is and does not go in some cases does not go when it is completely turned. What a thing with unicate
