Passat Transmission 1996
16 years 11 months before #3709 by manual-mecanica
Passat 1996 Transmission Published by Manual-Mecanica
Good afternoon:
I hope you can help me with a small detail that I have with my Passat, it happens that I do not find the rod to check the automatic transmission oil and on the other hand the first two changes makes it very beaten, it is revolutionized too much and when changing the engine to second or third, the engine kicks, although that does not happen all occasions, there are times that it does not.
Another thing, they tell me that these automatic boxes do not carry common oil such as dexron II but one mineral !! Let's see if you know something.
The car is a Passat 96, 2.0, 4 cylinders
thanks for your help.
