Greetings ... I have a problem with the Cherokee, I change the light bulbs from the original mopar bulbs and continue to show me the message of \ "tracera light failure \" All bulbs turn well on, as I do to remove the message. Thank you.
Check those of the enrollment and check the watt of the bulbs, it may be that you have put any with the wrong vatia heard, if everything is fine check the ground cables.-
