First of all, thank you for your Alfred attention, if I knew that the box next to the diesel filter is the one that regulates the heating time of the spark plugs is a black box which I have opened and has an electronic circuit and a bovine that functions as electriman and the ear feels the start of the beginning and completion of the time that is 14 seconds, which is not the one who gives the signal to the indicator of the board (signal of the luminous resistance (signal
What I am thinking is that Elemnto heats the bone spark plugs that happens to you electric current? The failure may be given that maybe it is not necessary to heat the spark plugs the 13 seconds and if what the board sends the 5 seconds for the consequent I can have an injector pump failure.
The black box or the two that finds are taking the board and if you look to the background you see the velocimetro gut and there is a sheet of sheet metal with the two very strong fastened boxes with a metal structure such as abrasaderas.
The car's model is Fiat Siena Turbo Diesel year 1997, frabicated in agentina with Utopartes from Brazil, Italy and Argentina. I have the vehicle since I left the factory bone from zero kilometer, I know it by heart, thanks Marcelo.
