Gasoline pump problems
16 years 10 months before #3967 by manual-mecanica
Gasoline pump problems published by Manual-Mecanica
I have a Renault 9 Super Mod 1993. I keep the following walking specially in the rise the engine temperature rises more omenous to the 3 heating lina and it is then that the gasoline pump stops working stopping the bottle, the pump has changed and the refregeration system and na follow the same thing that can be done ???? Thanks for your help
16 years 8 months before #4669 by manual-mecanica
Manual-Mecanica Response on the Re: Gasoline Pump Problems
If your renault is injection, it is possible that you protect you by temperature, or it is the feed of the pump tell me more and help you ..
greetings
16 years 8 months before #4699 by manual-mecanica
I do not think it is a temperature problem but of fuel fishing, at what level of fuel does that defect make you the lay fuel deposit or the floating or car's car that is covered they normally bring a filter on the tip.-
