Duna 1.7 Diesel Failure in cold start
16 years 10 months before #4071 by manual-mecanica
Duna 1.7 Diesel Failure in cold starter published by Manual-Mecanica
Frio failure the heater are ok the same way the setting; I even have it start with the primer then heat and go perfect. which can become the problem.
16 years 10 months before #4075 by manual-mecanica
Manual-Mecanica response on the Re: Duna 1.7 Diesel Failure in cold start
You say you have to start it with the primer. Check the aspiration of the cold pump, it is possible that it does not aspire enough diesel and that is why it costs it more to start.
