Clio Grand Tour Motor D4F 1.2 16V 102CV
11 years 1 month before #46357 by manual-mecanica
Clio Grand Tour Motor D4F 1.2 16V 102CV Published by Manual-Mecanica
HELLO EVERYONE !!
I have a Clio Grand Tour 1.2 16V 102 hp. From the year 2009
it has approx about 70000 km Yu for recently, you pull it if you step on it thoroughly.
Any suggestion?
In principle I suspect the gasoline filter or the ignition coil.
Where is the gas filter?
Greetings and thanks !!
11 years 1 month before #46367 by manual-mecanica
Manual-Mecanica Answer on the Tirones Clio Grand Motor D4F 1.2 16V 102CV
The filter is submerged in the pond, but if it is Renault Czech the coils, it seems to me that it has independent coils by Czech cylinders the spark plugs the same.
11 years 1 month before #46368 by manual-mecanica
11 years 3 weeks before #46411 by manual-mecanica
It is likely that it is the gasoline filter, (it is not inside the tank in that model I do not know but I think it is under the floor. It is also a possibility that if the filter is saturated, the injectors are covered, with which it would be good that you perform a cleaning by ultrasound system (it is the only effective method) there is also another possibility that it is about the fuel pump (it is within the tank of the fuel gasoline) Sometimes they begin to lose pressure and also the defect could be the pressure regulatory valve. Measuring the pressure with a manomentro
11 years 3 weeks before #46428 by manual-mecanica
Check the gasoline pressure and pressure sensor.
