I have a 306 TD 1900 of the year 1995 I have always had electrical problems with it, all the fans are operated at the same time, the stop light is turned on and yet the temperature does not rise from 90 degrees, I do not worry too much, but other times I have changed the temperature control box and solved.
It should be close to the battery if you want to follow the fan cables and you will find these cars they bring a connector under the battery that normally sulfate and give review problems review them and let me know.-
Thank you very much short circuit, I will look at it and I will tell you. The truth is that this forum is a fuck I have less than a month hooked and more and more flip, go ahead compis
