Sprinter 413 CDI problem
10 years 10 months before #46896 by manual-mecanica
Sprinter 413 CDI problem posted by Manual-Mecanica
Well estimated, I have been on the glow light of the incandescent spark plugs on for a long time, the spark plugs were very deteriorated by what I decided to replace them believing that the problem would be over but no, the light is still on and I do not know if it will be the timer and if there will be a short circuit, if so, how to check it? Thanks in advance.
10 years 5 months before #48305 by manual-mecanica
Manual-Mecanica Response on the problem with Sprinter 413 CDI
The light does not turn off because this the recorded fault
would have to connect the diagnosis and erase the fault and ready unless the timer box is damaged !! With a trial lamp you would have to try if it comes to the spark plugs
