Citroen C8
10 years 9 months before #47330 by manual-mecanica
Citroen C8 published by Manual-Mecanica
Good afternoon everyone.
I have a C8 C8 with intermittent failures. The temperature needle shortly after saving or when I have run a few kilometers, it goes but does not heat up and then the accelerator is dead does not work and after a while it returns to turn around
someone can help me
thanks.
10 years 9 months before #47336 by manual-mecanica
Manual-Mecanica Response on the Citroen C8
Hello, for the symptoms it can be the engine temperature collector, but to know fixed you should make a check of the engine breakdown
10 years 9 months before #47337 by manual-mecanica
: Blink: Thanks for your help I will review it
