Letroventillars do not work
10 years 8 months before #47385 by manual-mecanica
Letroventilers do not work published by Manual-Mecanica
Good morning I have a problem with the electro -seasons of an Hyundai Accent 2011, and I would like to know the connection of the temperature sensor, or someone who has the cycuito because apparently the output of the computer is failing ´The electro the direct probe they work I put a scanner to see the temperature the swensor works well stubbornly that detects me the scanner since I do not have for this type of brand
10 years 8 months before #47386 by manual-mecanica
Manual-Mecanica response on the subject reader do not work
Good morning, friend you check them, you must have a relay to work, additional there are also maxifusible to feed the electro, you must locate it and try them, unfortunately I notice the electrical scheme, greetings.
