Linear injection pump problem
10 years 7 months before #47776 by manual-mecanica
Linear injection pump problem published by Manual-Mecanica
I need someone to help me.
I have a Ford 1311 and Twngo truck problems with the start of it.
Check the injection pump and dismiss fuel for the 4 fuel outlets in the medium, do not pull any of the sides of the tips.
The bomb brand is Minimec Cab linear. Ayuuuuuddddaaaa !!!!!!!!
10 years 7 months before #47808 by manual-mecanica
Manual-Mecanica response on the problem with the linear injection pump
that I take the bomb to Chekar because although it is out of the point, the pump should throw PR all its cannon, this synchronized or not. If you don't have something there is in the bomb. Why did you already cry right?
