When the engine is accelerated
16 years 10 months before #4189 by manual-mecanica
When the engine is published by Manual-Mecanica
I have a problem, I have a 1996 Chevrolet Blazer Model truck, when accelerating the cough and sometimes engine.
What should I do?
Thank you
16 years 9 months before #4270 by manual-mecanica
Manual-Mecanica Answer on the Re: when the engine is accelerated
When you give it ibuprofen and an infusion with lemon, that vitamin C is good for colds. If you sleep outdoors, it warns it well that it does not take cold.
16 years 8 months before #4576 by manual-mecanica
If you do not go to mess, that \ "Petardea \" more than cough.
Look at the ignition system.
16 years 8 months before #4614 by manual-mecanica
Hello, I recommend that a scanned to see if the injectors ot work at the couple this failure, woohoo: woohoo:
16 years 8 months before #4619 by manual-mecanica
If the flat is with ing. Electronica shows the ignition, it may be out of point, if it is without intimation, cross the two spark plug cables and give it a little march, which hits two or three against explosions, connect them well again and probate, if you function well send it to make a good carbonation because it is covered ...
