Hello good afternoon I have a problem with my Suzuki Vitara 1.9 Td of the year 97, the problem is as follows: The car is phenomenal starts and it is fine but when I remove the key of the contact, the battery light is turned on in the box in the painting someone can help me ????
First Czech with the tester if you are actually loading and how much it is loading the alternator, if you load well you can have a problem with the integrated box or with the signal cable that sends the off signal off to the board you can even have a loose cable, at the time of accelerating the light is turned off or is all the time on.
Inside the alternator he has a triode if you have one in short can that happen to you to know it you have to disconnect a terminal being the vehicle off if he has a peculous pachage when touching it, it is possible that it is that
