Hello everyone, that the SRS witness is turned on, it means that its control unit detects a failure in one of its main circuits ... Therefore, it is turned on means that it is running out of Air Bag when the fault occurs, if you suffer an accident, God does not want it, and the lñuz is turned on, it will not display the air bag when appropriate. According to what you express, you must have a bad contact in the wiring, with the car running, move the wiring where the glove compartment is (Air Bag passenger), when the light is eased or turned off, there is the problem, if you are a methodical when doing this procedure you will detect where the bad contact is. Greetings and good luck.
