With a manual for the Clio, if you do not find that of the Express, you also are worth it. His would be to do it as the fellow Alvaro tells you, but you will have to assess the final price and what is worth the "van" ... If the thing came through a warm, check and change the thermostat or the leak (some sleeve, etc.) so that it does not happen again, when you have clean the plan of the cylinder head, check the plane of it with a rule in diagonal, if you are not combined, if you are not combined Diesel you would have to do some more things when rectifying .., $$$$) If you did not have oil or leak consumption problems, I would only put: COLATA BOARD- 35 euros+ DISTRIBUTION BELT, between 30 and 50 EUR, thermostat 25 EUR, and "with God" that is said ... that is not combined the cylinder head. Luck!!
