Bulb or sensor that lights clio fan
10 years 5 months before #48310 by manual-mecanica
Bulbo or sensor that lights the Clio fan published by Manual-Mecanica
I have to repair an 8 valve clio. The problem is that the radiator fan ignition or bolt is not in sight. Does anyone know what the fan can turn on when it reaches the temperature? Thank you.
10 years 5 months before #48311 by manual-mecanica
Manual-Mecanica response on the bulb or sensor theme that lights the Clio fan
I do not know what engine or how model there is a bulb or sensor in the radiator eg. Old models, Sure is the engine temperature sensor The computer takes the board signal and to operate the electro. Any doubt add vehicle and motor data
10 years 5 months before #48327 by manual-mecanica
Hello, I join what the colleague says and you can search the butt to wear two sensors one of temperature that tells you on the board and one of temperature that goes to the computer to control the electro ......
