I don't know what to make a burned shirt, it helps !!!!!
10 years 5 months before - 10 years 5 months before #48379 by manual-mecanica
Hi, I would like to know what I do with these shirts, I would like to know if they can be assembled or opened to do something thanks to what is going to do a chungo when I saw it when I have seen it
Last edition: 10 years 5 months before by . Reason: The photo was not uploaded
10 years 5 months before #48393 by manual-mecanica
Manual-Mecanica response on the subject, I don't know what to make a burned shirt helps !!!!!
Quiet the joint, also clean the "plane" of the block and buy that it is not deformed, rule to the song (that is trusted) and gauge of 0´05 or better comparator, if you go beyond 0´05mm "chungo" disassemble engine and plan block in terms of the "burn tries to pass a fine sandpaper (800) have if you disappear if you disappear
