I have a P2140 fault with the suspension of a Navigator 2001 lincoln someone could tell me where is the computer or the suspension controllers to be able to check the feed line of the inflation of the airbags thanks
Compressor Under the battery, pump relay by the same compressor area, supply module of the level sensors, on the frame of the passenger side coupled to the frame is a 15x15 plastic box with double connector
