You do not need Manual Check that the 5 vols of the fuel level marking arrive in the pump file if they arrive this voltage, it is little that this is the problem on the scoreboard or in the cable that goes to the board or the same board to know better bridge the food cables of the marker not of the pump since there are 12 vy mass could cause a short circuit greetings
