I have a problem with a Delta 2.0 16v lance, I don't get current to the ignition coil I have reviewed fuses, relays and everything is okay, can you help me?
I guess you have no corturient, that you have looked at the cable that goes to the coil is not cut from where it comes (test with a direct positive from battery feed coil and see if it starts) I do not know if in this car comes direct from the Bombin de la Llave .. ?? for giving you some idea ... greetings !!
