Subaru Legacy 2.2 does not turn on
10 years 4 months before #48603 by manual-mecanica
Subaru Legacy 2.2 does not light published by Manual-Mecanica
hello. I have a Subaru Legacy 2.2 4WD Motor EJ22.
It does not turn on does not arrive signal to activate coil in cylinders 3 and 4. The ignition module is changed and the failure continues. There is an activation signal in the 4 injectors and in coil 1 and 2. Media continuity in cables and all OK. It will be possible to be ECU.
10 years 4 months before #48631 by manual-mecanica
Manual-Mecanica response on the subject Subaru Legacy 2.2 does not turn on
Axle Sensor Ok. Proven coil too. OK crankshaft sensor. ECU proven and continue giving the same failure. Wet spark plugs and only spark sign in 1 and 2 cylinder. Continuity reviewed in all sensors.
10 years 3 months before #48664 by manual-mecanica
Solved. Anyway, the distribution was badly placed. I was felt that they had revived her before in another workshop. (or maybe not). Well I put it as it should be and everything ok.
10 years 3 months before #48665 by manual-mecanica
