Help with elector fans, Nissan B15.
10 years 3 months before #48677 by manual-mecanica
Help with elector fans, Nissan B15. Posted by manual-mecanica
Hello I would like to ask for your help, I have a problem with the elector fans of a Nissan B15, QG18 engine. Since I have the fans all the time, I already change the refrigerant temperature sensor, check the relay, but the problem still persists, no matter if it is cold or hot, when it turns on the car it takes about two seconds and ignites a fan and then change at the strongest speed and turn on the two fans. The car makes a scan but does not present any code.
I would very much appreciate your help.
10 years 3 months before #48678 by manual-mecanica
Manual-Mecanica response on the subject Help with elector fans, Nissan B15.
Hello, test with the air conditioning off
10 years 3 months before #48692 by manual-mecanica
Hello, look that the problem does without air conditioning. With the air off the two fans always remain on.
