SEMATIDO GLX 1.8 YEAR 92 PROBLEM 92
16 years 9 months before #4261 by manual-mecanica
SEMATO TOLEDO GLX 1.8 year 92 problem published by Manual-Mecanica
Hello everyone,
I have a small problem with the relief of my Seat Toledo is the 1.8 monopunto GLX of 92
I start and stay at 1100 rpm at 2 minutes it becomes totally unstable from 1100 to 1500 to 1800 to 800 to
1400 Blue filter that has and still does the same, does
anyone know what can be ???
Thanks
byer
16 years 9 months before #4268 by manual-mecanica
Manual-Mecanica Response on the Re: Problem Seat Toledo GLX 1.8 Year 92
The first thing you should do is disassemble the idle valve and clean it well.
16 years 9 months before #4322 by manual-mecanica
Hello, I am Juan and I want help to solve a problem in a fiera fiera with TD 42 to 3400 meters of height the engine gets slow and does not respond moisturns and heats the bonba and the toven are new help Pofavor
16 years 9 months before #4326 by manual-mecanica
is that valve inside the monopunto? I have seen 2 valves that are anchored next to the monopunto that receive several empty tubes, are those?
Is there any problem in disassembling the monopunto clean it and mount it as it was? or need some more accurate adjustment when it comes to riding it
thanks
byer
16 years 9 months before #4449 by manual-mecanica
Two things clean the acceleration body and change the water temperature sensor that can be created false readings or the connector has some broken average cable
