Fifth, Clio 1.6 year 2005
10 years 2 months before #48965 by manual-mecanica
Fifth Traved, Clio 1.6 Year 2005 Published by Manual-Mecanica
Hello friends
I need your help ... In the exchange box, the fifth is locked .. I do not know what it can be, 1, 2, 3 and 4 pass without problem, but when passing the 5, it does not enter and feels a strange noise when making a little pressure. Please thank your opinions ...
10 years 2 months before #48967 by manual-mecanica
Manual-Mecanica response on the fifth traved theme , Clio 1.6 year 2005
Hi Claudia,
if a march does not enter there are several possibilities, the most important to diagnose is always necessary to go back
when it happened, in which management circumstances (if you committed unerror when passing the march, etc.
then describe well. If it is only the fifth, and the clio walks in all the other marches including the reverse
or not, if it scrapes when trying to pass the march and it can be
looked
10 years 2 months before #48988 by manual-mecanica
Hi Clauam, as Juanvasquez tells you, it is important to review how the thing started, in these cases it may be that if it is not raged when changing, synchronism is damaged, does it come in a stopped engine? If so, I would touch it, (the piece is expensive), it can also be a caps of the worn or broken command that does not allow to move throughout the 5th route, do you still enter the engine stopped badly? Greetings!!
10 years 2 months before #48992 by manual-mecanica
The most common thing is that the synchronized ring of the 5th is split or the nut of the secondary axis is loosened, usually it is not necessary to remove the box to repair it, the lid is removed only.
Luck
