Mercedes vehicles lead to the entrance of heating a solenoid valve that opens and closes the passage of water to the heating radiator.
You must control this solenoid valve.
It has two cables; One is a positive 12v. The other is a square signal of mass that sends the climate unit.
The operation of the valve is as follows; Without unit sign, it is open and there is water passage to the radiator, therefore hot air will come out of the spracks.
With unit signal, the valve closes preventing the passage of water.
Check the operation.
