I need help with a Ford Escort
16 years 9 months before #4290 by manual-mecanica
I need help with a Ford Escort published by Manual-Mecanica
Hi, the air and fan has stopped in a Ford Escort and the fuses are fine, I need someone to tell me if it can be a reverse and where to find it.
16 years 9 months before #4291 by manual-mecanica
Manual-Mecanica Answer on the Re: I need help with a Ford Escort
What air have you stopped? What fan doesn't work? What engine is it? model, year, ..? A little more information to write is free and with the village vehicles are not fixed.
16 years 9 months before #4292 by manual-mecanica
It is an escort of 96 injection 16V. The engine a 1.6 EFI
what has been gone is the air conditioning system (air conditioning and ventilation)
16 years 9 months before #4295 by manual-mecanica
Well, the first thing to do is check if the circuit has gas. For that you have to connect the air conditioning recuperator and check the high and low pressures, with the vehicle to idle and engine stopped, they have to be equal to 6 bars more or less.
If the gas load is correct and the pressures too, the electrical parts will have to be verified. You have to connect the air conditioning and check that it comes positive to the compressor clutch. If it does not arrive, we will bridge the trinary valve. Once bridged, the motor fan must be lit and the compressor is activated. If this happens, it is necessary to replace the trinary, but ... the installation that is not cut must be reviewed.
This is \ "roughly \" the steps to follow to check the air.
All the best.
