Hello, I have a mini 850, the escape flange with the collector, is bitterness of my life. I changed the flange, put pasta for escape assembly, everything clean. And it still has a gas leak, and the air filter dirties me at a few kilometers. Any idea? Also say that the cone of the tube and the collector output have no deformation.
On the other hand, the windshield wiper has never worked well. Without strength, and where you feel like it. I disassembled the motor, cleaned it and put a new induced. Since the inducting coil has continuity and nough derivations. The brushes are whole, without scratches, there is no damaged cable in the engine. The varillage works soft (a kind of zipper. But it still does not have strength. Thank you very much. Greetings, Joan
