Install a Cluch and does not work, the slave cylinder goes too much the lever that moves the necklace as it does not return and makes the cylinder have to leave, when it should activate the cluch and the same time the same inertia when the cluch enters, make the arrow of the cylinder return asce. Without working the cluch who can give me some tips or point of view to the problem I have with my car
Hello, perhaps if you gave us more vehicle data we could reach some conclusion of the failure which can be several ... When disassembling the system was emptied? However, I can notice what the press does not work for, that is, there is no resistance ... will you not be with the disk to the reverse ??? You tell us. Luck
Hello for what you say I recommend you disassemble and review the following details: the fork that the collar operates should not be crooked and in many models it carries a bolt that ends in a ball that makes the fork pivot you must also check its condition and grease. Before disassembling the press, look that the diaphragm of the press is not sunk in its center, that is, it is not plane with respect to the body of the press if it is means that the clutch album is very thick. Also corroborate what Mov 1973 tells you about the position of the album. I hope I have helped you and what solutions your problem.
