It would be necessary to know if the pressure bomb is put contact before starting and off the board witness light.
Mov1973 wrote: Dear, a common fault in these Fiat is the crankshaft position sensor located on the side of Dumper, check its correct subjection of it and its connector, this in its failure shorts the signal to the coil and the fuel pump. You tell us how it went. Luck.
