Hello estimates
I have the next problem, I have a Nissan V16 year 1998.
It turns out that when I start walking I have a sound on the right wheel as if the caliper or the pills were loose and when driving around 40km/h the car in addition to moving a little the steering wheel
the car has as a sway it seems that you were dancing little bachata.
When the sounds are accelerating until it reaches 70km/h it turns out as a
CT Tac Tac Tac Tac Tac, as if the tire had a stone but it is not so. The thing
is that the sound increases according to speed. And it is transmitted through the floor,
the pedals etc.
Check with the little and nothing I understand, the pills are tight along with the caliper.
The wheel nuts were also well tight (before they were), it should be noted
that the tires are a bit spent.
When I checked the wheel pieces, notice that there is a iron that comes from the
engine block to the dough (if I'm not mistaken) that when moving it has a certain game, but does not sound or similar
to what corresponds to what I feel inside the car.
My doubts are:
How dangerous can it be? Wave will fly a wheel?
What will it be? Mass? Homocinetic? Stabilizer bar? Any worn rubber bushing?
Attentive to your comments and in advance thank you very much.
