Nero Escape Crdi Hyundai 2010
9 years 10 months before #49736 by manual-mecanica
smoke Nero Escape Crdi Hyundai 2010 Published by Manual-Mecanica
Friends I have a job of work Huyndai Crdi 2010 expels Black smoke by escape review mechanical and said it was Erg dirty, clean erg I serve and wash also serve the multiple of admission and clean it check injectors in the test bench and indicated that they were fine and even mount and idle does not emit smoke but by accelerating very fed up black visible smoke that cuts when it cuts when I go in 4th. Disconnected sensor that is on hose filter that goes to the turbo and stops emitting black smoke but did not accelerate more than 3000rp x min. The mechanic has scanned it and only delivers as an indication Sensor of mullion which indicates the mechanic that does not inside in emissions control review oxygen sensor and my problem continues to beg if someone has a fault of failure will tell me what engine it has strength only that I started emitting black smoke: I put additive to the antihummo fuel but nothing happened, it does
not
consume
9 years 10 months before #49744 by manual-mecanica
Manual-Mecanica Response on the topic Nero Escape Crdi Hyundai 2010
The clutch sensor affects this one, gives signal and usually makes the advance and flow decreases so that you can get out of RPM and you can get better, if it comes out in the scann, the connector is to be checked in case it is evil or it is broken ... put that it has been given a sign of "clutch stepped on There the smoke ..), is what seems to me the relate that the clutch sensor can have in this. You will tell us what I am. Greetings Antonio1 !!
