Hello people! The workshop peug scapade arrived to the workshop (it is similar as peugueot 206 auto gasoline). The client has a short time and consult if the temperature that the engine arrives is correct. They are 97*C degrees. controlled by the board and Scaner. I change the doubts the temperature censor and continue to maintain Temp Max. When the electrventilator turns on, it makes it come at 90*C, is it normal?
Good colleague, I would like to know what model it is, well and does not work at that low temperature, it must be that they removed the thermostat, it must work as 110 120 degrees if I'm not bad
Hello, I have a fact, I hope the thermostat opens to 89c ° the fan in its first phase is connected to 96c ° in the second phase 105c ° This data is for models from the years 2000 to 2005 but there is not much difference with other years
