Astra Chevrolet 2005 - Does not turn on
9 years 9 months before - 9 years 9 months before #49971 by manual-mecanica
Astra Chevrolet 2005 - Does not turn on by Manual -Mecanica
The car's light is turned on with the key on the board (indicator), the car does not keep the ignition, as is drowning and avorates little black smoke through the mofle, all the fuses and relays were checked and they are fine, I also change the kit of the gasoline pump for a new one also also installed new gasoline filter ... the oxygen sensor is also new, it was new, it is new, it is new, it is new, it is new, it is new, it is new, it is new, it is new, it is new, it is new, it is new, it is new, it is new. Before it no longer worked correctly that on the road I noticed that the car pedio car (force) and then pass what to explain that it drowns and does not keep the ignition.
thank you.
Last edition: 9 years 9 months before by . Reason: bad words
