LOCATION MOTSUBISHI MOTOR THERMOSTAT KATANA L200
9 years 8 months before #50167 by manual-mecanica
: UNSURE: : UNSURE: In which part of the Mitsubishi Katanna L200 year 2009, the thermostat is located, I must change it because the radiator water boots.
9 years 8 months before #50168 by manual-mecanica
Manual-Mecanica response on the topic Mitsubishi Katana L200 Motor Termostate
First of all locate the water or refrigerant leak, second correct it and verify if the cooling system is working in accordance with the technical specifications, if the vehicle presents failure due to temperature, diagnose the hoses that have the same temperature, if not for that reason you must replace the thermostat and that is located where the upper engine of the engine begins towards the radiator.
