Hello mechanical partners ....... I have a 2002 Ford Escape with 4 -speed automatic transmission is the CD4E but it turns out that the first and second one enters very well but does not change to third or fourth speed ... and after 3000 revolution A diagnosis and did not come out of a sensor or solenoid .... I only throw these two codes that leave me in the same P0733 and P0734, that the only thing that tells you is that it does not change to third and Metallic and pasta and drums and everything is fine, even change the valve box and check the solenoids and all are fine but the transmission nomas does not change ...... I hope and someone gives me some idea something that happened to me ...
