I apologize for a problem and I would like to know if they can help me it turns out that the client has um greedy ml 430 year 99 and is immobilized and does not turn on the scanner comes out the ignition failure with its respective fault code, I thought I solved by cloning the key but there is no key for which it says that the washing machine would be entered. I appreciate your help in advance greetings
