4m40 t TPS cables
9 years 4 months before #50607 by manual-mecanica
4M40 T TPS Cables Published by Manual-Mecanica
Hello, grateful for the information to the Chilean friend of the TPS adjustment, but I forget to comment that only the sensor side connector has, on the other side the loose wires are and I do not know which one goes with which one in the sensor, again thanking for all the help thanks ......
9 years 4 months before #50608 by manual-mecanica
Manual-Mecanica Response on topic 4m40 t TPS cables
Hello, what tps is it? 3 cables? Do you have to have the dough, signal and 5V in that case.- On the side of the ECU, do you mean? I do not understand when you say the calbes of the sensor side twice. greetings.
9 years 4 months before #50609 by manual-mecanica
Hello, I clarify the male connector that connects with the TPS female connector and the TPS is three cables, my question is where the cables are both the signal and the voltage in said sensor connector since nothing else has 1 connector or on the other side there are only the loose wires thanks.
9 years 4 months before #50610 by manual-mecanica
How, you must measure with a tester and check that reaches you from the cables from the ECU, one is mass, the other signal and the 5V of food if they are 3 cables, if the Medis you take it out, then the connector has only one position to plug. There is no margin of error. greetings.
