The engine is repaired since it was left without oil because the crankcase broke and it went on and did not try to scan it and achieve it liabing with the vehicle therefore it brought another scanner and the same, remove the computer and tried the other vehicle and it turned on in a normal way they already checked the fuses and all are fine, the strange thing is that when you open the suiche does not turn on the chek or marks the fuel indicator. collaboration
