When it is in idle the engine gets irregular causing the entire vehicle to move at that rhythm, but it is enough that the revolutions 50 rpm more disappear immediately the irregularity. My question is: Is there any way to adjust to increase the idle speed?
Good afternoon, you must work between 900 and 1000 rpm and to accelerate it has a screw on the fuel pump where it stops, adjusting that screw has to lift the safe march. I hope it helps you
