Nissan Navara position lights on position do not
8 years 6 months before #51826 by manual-mecanica
They do not light the Nissan Navara positions published by Manual-Mecanica
Hello friends. I made a short circuit in the position and brake lights, but I only found the burned brake fuse, change it and work well. But the position does not find it, check all the fuses and there is no burned, the lights are good, but they do not light the rear, there will be some fuse elsewhere or it will be something else. Relay, since it is weird, all the good fuses are and the lights tried them directly and they work well, but when the night lights light it does not turn on.
8 years 6 months before #51827 by manual-mecanica
Manual-Mecanica response on the subject does not light the Nissan Navara position lights
Hello in the Navara D40 the lights are controlled by an electronic body of body. If you cut and there are no burned fuses, the circuit Q does not work can be electronically fuses ... The module detects the cut that you made and protect the circuit.If is the above you must erase the memory memory of the BCM with scanner. The other is that you try disconnecting battery a few minutes and connect to see how it goes.sl2 and luck.
